Choosing the right sway bar for my car
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
My car is a 92 RS with a 385 fast burn v8. The suspension is mostly stock now but i want to upgrade the sway bars and bushings in the front and rear. Right now I just have subframe connectors on the car. I use my car as street/strip. No real major racing just look good on the road. I wonder what would be the best drivable setup with the most performance?I was also gonna add a wonderbar at the same time.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Choosing the right sway bar for my car
dont forget shocks struts springs and tires, they are more important than sway bars.
as for sway bars, find a factory 36mm front, 24mm rear and start there. Sometimes a slightly smaller rear bar will work better than the larger one.
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
NBrehm
Aug 5, 2015 07:57 PM
