Best Of Everything...
Old Sep 14, 2001 | 08:30 PM
Tyler-88's Avatar
ok guys, here is where all you smart people come in. i got my edlebrock springs (eibach spell?) and now im going to do everything. i got plans for an engine that will have 500hp and i need the suspension to be able to handle the power, keep me on the road and give me the best ride possible. please reply with your recomendations on the BEST of all suspension upgrades, thanks alot.
Old Sep 14, 2001 | 09:06 PM
poncho9789's Avatar
First off get some subframe connectors those will help keep the car from twisting. Get some control arms. Get a panhard bar. and get a torque arm to get the car to launch. try spoon products there are alot of guys that will reccomend his parts without hesitation,but they are expencive.
Old Sep 14, 2001 | 09:28 PM
Tyler-88's Avatar
spoon/spohn is the "best" produces of all the mentioned products? i want the best product for eatch piece of hardware...
Old Sep 14, 2001 | 10:04 PM
87RS402's Avatar
If you really want the best then Kenny Brown is the only choice, period! People can say what they want but Spohn products are not designed, or engineered, they are built. He takes a stock piece and builds a stronger replica, thats it. The KB pieces are engineered to work and are usually lighter and stronger than the parts they replace, unlike the Spohn parts. Don't get me wrong, Spohn does build strong parts and has had good luck with them. It's just the KB designs are far superior in almost every way. The reason Spohn has such a great following is because he sponsors this board, if KB sponsored this board also then they'd have a great following too.
[This message has been edited by 87RS402 (edited September 14, 2001).]
Old Sep 15, 2001 | 08:42 AM
Tyler-88's Avatar
do you have to ship your stock suspension pieces away to KB? and how much does KB cost more/less than spohn parts. how about the best shocks/struts. do you think racing shocks and adjustable struts in the front?
Old Sep 15, 2001 | 11:35 AM
87RS402's Avatar
www.kennybrown.com/fbodymain.html
No, you don't have to send them your stock parts, everything they build is a brand new piece. Shocks and struts are something I haven't really got into so I'm hesitant to give suggestions. There are others on this board more qualified than me that can help you choose them.
Old Sep 15, 2001 | 03:37 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
As far as shocks go, Bilstein or Koni is probably the best.
Old Sep 15, 2001 | 06:17 PM
Tyler-88's Avatar
thats what i was told today. which is THE best? just pick one?
Old Sep 15, 2001 | 08:35 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
From everything that I've read and heard, Bilstein makes the best shocks, Energy Suspension makes the best busings, and Eibach makes the best springs probably. As far as for LCAs, panhard bar, torque arm and SFCs it might be a toss up. I've heard awesome things about Spohn and the same about Kenny Brown. Which one is the superior product? Well, I doubt you will get anything but a debate about that. That's something you will have to decide for yourself.
Old Sep 15, 2001 | 09:12 PM
87RS402's Avatar
Given the above choices, I'd take the Koni's everytime. That's all they do, high perf shocks and struts.
Old Sep 15, 2001 | 09:23 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
www.ground-control.com
that's the best hands down. I've got Eibach's and Tokico Illumina 5-ways. And all spohn stuff with a www.wolferacecraft.com 8 point cage.
I'm running about 500 hp 383 mini-ram etc. Spohn is by far one of the best. Other than that, i'd say www.lgmotorsports.com all products track proven and Lou started out in thirdgens. World champion titles.
Old Sep 16, 2001 | 01:44 AM
Jza's Avatar
Jza
How exactly do you "engineer" a control arm or panhard rod? The only relevant specification in those pieces are eye-to-eye distance, and since they're both (KB and Spohn) adjustable, that's moot point.
The rest is about material and appearance.
I can perhaps see "engineering" a torque arm, since there's a little more involved. Same for the subframe connectors.
I'd just like to see some specific examples of why you think one superior over the other.
