SBC BMR KMemeber to LS1?
Old Oct 18, 2010 | 08:31 PM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Can a SBC bmr k-member be converted for an LS1 motor? Thanks for any help.
Old Oct 19, 2010 | 09:28 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Re: SBC BMR KMemeber to LS1?
Ugh I hope someone has an answer to good a deal to pass up.
Old Oct 19, 2010 | 04:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could always give BMR a call and ask?
i read somewhere, i think it was here, that their k-member was actually designed around a lsx engine. So i assume it would work with the proper motor mount.
Or give them a call and ask
Old Oct 19, 2010 | 06:24 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
I keep meaning to but kinda a good thing i didnt because... Its a spohn K-member. Guy has no clue what he really has.
Old Oct 19, 2010 | 06:40 PM
Pocket's Avatar
Car: 91 Trans Am
BMR and Spohn are two different animals
BMR uses extension arms that mount directly to the engine mount, Spohn has flat pads to bolt your mount to in addition to the one on the engine block
Look at pics and see for yourself
Next, the LSx mounts are set in the V6 position which is the very rear for a stock K-member. Its a few inches off for the tubular, youd have to cut and weld or use the cheapo SBC adapter plates
In short, you can get it to work, just dont expect a breeze to install. If its a Spohn piece, dont bother sending them a msg asking to convert something. If you're not buying a new piece they give you the 3rd degree
Old Oct 19, 2010 | 08:23 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
I looked at the pics of the 2 and its def a Spohn peice. So could I just use the plates i have now for my swap and be ok? I dont mind a little work for how cheap I'm getting it, just cant do much cut and weld as i suck at the weld part. LOL
Old Oct 20, 2010 | 07:26 AM
Pocket's Avatar
Car: 91 Trans Am
Yes, the adapter plates with the SBC block mounts
Old Oct 20, 2010 | 01:44 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Yes, Spohn's SBC k-member will work with the proper LS mounts. I have Spohn's K-member and there are provision's for both SBC and LS mounts.
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
