Vibration?
Old Oct 21, 2010 | 12:54 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Vibration?
have 89 iroc and I have a vibration that feels like it is coming from back passenger side. Had worn out and dry rotted tires. So i wound up buying a set of chrome irocs with new tires balanced and shipped to my door. I still have a vibration at 55mph, and feels like its coming from back passenger side. ANY IDEAS? thanks
Driveshaft?
spring?
shock?
Old Oct 21, 2010 | 01:31 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Vibration?
did it randomly show up or has it always done it?
Old Oct 21, 2010 | 02:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Vibration?
And have you performed a visual for bent, broken, lose parts?
JamesC
Old Oct 21, 2010 | 04:10 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: Vibration?
Have someone follow behind you to make sure you don't have a bent axle , that would usually do it all the time .a driveshaft would be a middle vibration not to one side or the other. Springs and or shocks usually wouldn't cause a vibration .
Old Oct 22, 2010 | 12:21 AM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Re: Vibration?
Its kinda always done it, and yes i've done visual inspection and nothing is broken. Ill check for bent axel though. But it would seem if i had a bent axel it would vibrate all the time. Thats why i always thought it was a wheel or tire problem, like out of balance or broken band it tire or something.
Old Oct 22, 2010 | 08:28 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Re: Vibration?
If it only starts coming in at a higher speed, and the car has always done it and still does it after you swapped wheels and tires, then I'll lay money that it's the driveshaft. Thoroughly check the u-joints, and make sure there isn't too much slop between the slip yoke and the transmission. If the joints and yoke look good remove the DS and take it to a driveline shop to be ballanced. Most shops will ballance a driveshaft for $50-$75..
Old Oct 22, 2010 | 11:54 PM
WHTrunner's Avatar
Car: 1986 Z28
Re: Vibration?
How much slop in the slip yoke is acceptable? I've got maybe 1/64th of an inch of slop.
I've got the same problem as OP, only mine seems to be coming from the front. I already replaced everything on the front, so I started looking at the drivetrain. I found a ding in the driveshaft, and swapped it out tonight, only to have it do nothing for me. Already put new u-joints in. I was wondering if I had too much slop in the yoke, but I really don't know what is too much.
Old Oct 23, 2010 | 06:16 AM
JamesC's Avatar
Re: Vibration?
Any chance you're running a poly trans mount?
JamesC
Old Oct 23, 2010 | 08:26 PM
WHTrunner's Avatar
Car: 1986 Z28
Re: Vibration?
Me or him?
I'm not sure what it's made of.
Old Oct 24, 2010 | 10:00 AM
JamesC's Avatar
Re: Vibration?
Originally Posted by WHTrunner
Me or him?
You. Poly can introduce significant vibration in some applications.
JamesC
Old Oct 25, 2010 | 10:12 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Re: Vibration?
shouldn't be much more than 1/16" i'd say. That is just a speculation based on how much my TKO600 has...
Old Mar 18, 2011 | 10:14 AM
squatingeagle's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.23 posi
Re: Vibration?
service manual says its a rough rear wheel bearing. ive got the same problem right now. ive replaced the drive shaft, u-joints, axle shafts, and tires. i dont have bent rims and ive got a gm trans mount. im going to run it today with axle shafts out and that will tell me if its the bearings. if it doesnt vibrate, its bearings
Old Oct 20, 2011 | 12:50 PM
Car: 91 Z28
Re: Vibration?
its was rear wheel bearings. replaced them runs like a dream
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
