Anybody have/use the Ground Control Adjustable Height Front Spring Kit?
Old Sep 25, 2001 | 06:05 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I am looking into getting this front spring kit as it will allow me to adjust the ride height for whatever I am doing (ie street driving, road course, or drag racing) and I won't be stuck with one height. I am wondering if anyone is using this kit and how they like it if they are. It sounds really nice with a jack screw that can be adjusted through the hole in the middle of the lower spring perch. For those of you wondering about this kit check out www.ground-control.com for more info. I have already decided to get their rear adjustable kit as a friend of mine has this kit on his 96 Z28 and it is very nice . It has a billet adjuster that slips into the lower spring perch that the spring sits on and has a spanner-nut style adjusting sleeve to change ride height and corner weights.
Thanks ahead of time for any info,
Matt
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Sep 26, 2001 | 10:42 PM
Matt87GTA's Avatar
ttt
Old Sep 27, 2001 | 08:39 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I haven't used it, but when I contacted Koni about a coil-over system, that's what they suggested. In fact here's the exact response:
"We only have shocks available for your vehicle. If you want to upgrade to a coilover system, you would have to use a coilover sleeve (like Ground Control) with our shocks. Otherwise, you would have to have something custom made. I would check with Ground Control as this is a cheaper alternative and the Sport shocks can be matched to work will with this system. If you have any other questions, please let me know. Thanks."
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Pictures: http://albums.photopoint.com/j/Album...=13412261&f=0]
Quote: "If you can't beat them, arrange to have them beaten."
- George Carlin
customblackbird
Aug 15, 2021 10:16 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
TA8487
Aug 11, 2015 09:02 PM
