Do Auto trans cars have different spring rates than manuals? car sitting high in frt
Old Oct 24, 2010 | 04:52 PM
1RedCamaro's Avatar
My car was lowered. After that I converted to a T5 From the 700r4. I decided the lowered springs were too harsh for the street. So I put the stock ones back in.
Now the stupid car sits and inch higher in the front than it does in the back. Is this because of less weight of the manual trans? The a arms look fine and everything went together right as there is really only one way to put the springs in.
Now if i want to correct this, do i need to get a set of stock springs from an iroc manual car? ugh, what a pain.
Old Oct 24, 2010 | 05:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Do Auto trans cars have different spring rates than manuals? car sitting high in
there isnt that much of a difference in weight between teh two trans setups, not enough to affect the height that much.
did you index the front springs when you installed them? there are 2 holes in the spring pocket in the a-arms, in the back, the end of the springs needs to be between the two holes, same on both sides.
have you driven the car since?
Old Oct 24, 2010 | 05:08 PM
1RedCamaro's Avatar
yea its been about a 1000 miles. I think it may be the sway bar, I tightened it up before i set the car on the ground.
My car is just a z28 tho, do the irocs sit lower? mine was an original tpi car just not an iroc.
Old Oct 24, 2010 | 05:17 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I had done the same thing when I installed my sway bar, but it didn't take 1000 miles for the front of the car to return to normal ride height. I also think you should check to see if your front springs are indexed correctly.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
