Where to find a 36mm Hollow Front Sway bar?
I am looking for a 36mm front sway bar for my 89 RS, does anyone know where I can find one or who might make one. I have tried Addco and they only carry 32mm hollow.
Car: 1992 RS
Engine: 406 Stealth Ram
Find one off an IROC. You'll need new bushings, too. I got poly bushings from Guldstrand Engineering.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you will also want to replace your rear sway bar, to match, i beilve the matching sway bar is 24mm. if you don't have the front and rear matched, your handeling will be worse.
[This message has been edited by Dewey316 (edited October 04, 2001).]
Actually if you are running a 36mm hollow up front and a 21mm in the rear that is the best setup for the 24mm rear bar is too large and stiff and cause the car to skidout. I am also going to run a ground control panhard bar and SLP reinforced lower control arms. i think this is going to be a great setup for either autocross or drag. The only reason it would make the car handle worse is because the driver can not compisate for the diffrence! JMO
Axle/Gears: 3.45, 3.27, 3.27
Don't forget they were available on the WS6 equipped 'Birds too. I bought them new from GM (or so I thought). I sent both bars out for powder painting. Only to discover that they goofed. The front bar was for a 4th Gen instead of a ThirdGen. We picked up a used one at a local Pick-A-Part that afternoon. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
