I can't get my rear rotors off!!!!!! Help!!!!!!
Old Oct 4, 2001 | 03:28 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have an '89 GTA with a 9 bolt and factory discs. I can't get the rotors off the back. The caliper is off. I have tried heat, penetrating oil, and a little persuasion using a mallet. I am not sure if I will damage the axle by wailing on the rotor. These rotors have been on here for a while
92Z28
89GTA
Old Oct 5, 2001 | 12:39 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Anyone?
92Z28
89GTA
Old Oct 5, 2001 | 02:54 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I had the same problem last week. I used a hammer and a 2x4. The wood won't hurt the rotor and you can pretty much beat the hell out of it. It should come off eventually... nothing a little "mechanical agitation" can't fix. I'd stay away from the heat though. Good luck
Old Oct 5, 2001 | 09:34 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I had the same problem with a used rear end I bought. I drilled several (as in many) very small holes at the intersection of the rotor and axle. Just keep drilling holes, penetrating oil, tapping with a rubber mallet, drilling holes... until it comes off. This method assumes you will be trashing the rotor. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
