lowering?????
Old Sep 29, 2001 | 06:46 PM
agawam's Avatar
lowering?????
with the minimum of ground clearence why does everybody lower their cars? this doesent just apply to 3rd gens but I see it bieng done to everything out there,and don't give me the center of gravity song.I built a vette a few years back that would outhandle anything it came up against,would eatup any corner at any speed and was 5 inches higher than stock.I want to know whether its cosmetics or a real need-to do thing
Old Sep 29, 2001 | 09:30 PM
82camaro's Avatar
Car: 82 camaro SC
Lower center of gravity will handle better. It looks nice as well, IMO. Usually the drop springs are also stiffer, which helps handling. That vette, sitting 5 inches lower, would handle even better.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 30, 2001 | 09:22 AM
poncho9789's Avatar
agawam: what did you do put a five inch lift and a set of 31x10.50s on that dam thing.
ROFLMFAO!!!!!!
For some reason I just don't believe this post.
Old Oct 3, 2001 | 10:23 AM
FiReBReTHa's Avatar
limp bizkit.....
'rollin, rolling, rollling rollin, YEA"
lol
ive seen that pic at www.sounddomain.com
lol, muddin cj
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 6, 2001 | 07:33 AM
agawam's Avatar
the vette had big block front springs and a 312lb 5leaf rear ran 255x60 fronts and 275x60 rears with 74 454 bars(gymkana)and cheap delco shocks and every bushing was replaced. I live in New England where we have roads that are not flat and the dpw is constantly raising manhole covers and gas/electric access with all the potholes frostheaves and speed bumps lowering is the last thing I want to do
Old Oct 8, 2001 | 12:43 AM
Kandied91z's Avatar
5" lift man i would look like a stock car next to that with my 4" drop!
ever go muddn with that thing.
[This message has been edited by Kandied91z (edited October 07, 2001).]
Old Oct 8, 2001 | 01:29 AM
AntiVTEC's Avatar
5 inches higher? Put it this way, if lowering wasnt nessicary then NASCAR, CART, NHRA, Formula 1, and SCCA wouldn't bother laying their cars down as close to the ground as possible.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Oct 9, 2001 | 06:00 AM
agawam's Avatar
ya'll can lower them as much as ya want but to me its just fashion,like wearing pants that are too big, they drag on the ground and unless you have a big number on your door its just expensive designer crap how many times a year does your car run NASCAR CART or F1 or should I say how many times are you going to replace your exhaust or ground efx,trans pan, ect.They don't call it slammin for nothing
Old Oct 9, 2001 | 06:49 AM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Here is a for instance that will prove that lowering improves handling. Pick up the S.C.C.A. Rule Book and it will tell you that if you lower your car, you will move up to a prepared class, read : FASTER.
Not only does it make the car handle better but it sure makes a car look mean with a lowered stance. I love looking at brand new cars and trucks on car haulers coming from the factory because they look lowered when the are tied down and the suspension is compresed.
What everyone has to realise is that automobiles are a matter of personal opinion and expression. The little old lady at the stop light doesn't understand the passion I, and I'm sure you too, feel for Camaros and modifying them to meet personal standards and visual apperances.
What I'm saying is that you have to respect what someone else loves, I didn't say you had to agree with them, but respect it. A buddy of mine got pulled out of a ditch once by a jacked up Pinto with big off road tires. No one I knew agreed with his choice but we respected it once we were out of the ditch.
Old Oct 10, 2001 | 05:48 AM
agawam's Avatar
no disrespect intended all I'm saying is lowering is track stuff and exhaust systems,ground efx,and other things found under the car are expensive why risk the cost of replacement, besides that if you are going fast enough on the street for the lowering to be effective you are probably a danger to civilization.I'm doing an 86 T/A and I'm not going to lower it and I bet it will handle just fine
Old Oct 10, 2001 | 12:11 PM
AntiVTEC's Avatar
Lowering the CG is critical for better handling. Look at football players: They stay low when getting ready to hit somone so that they can get as much control as possible. Other wise, you'd be seeing sports players standing up straight all the time.
Its laws of physics man, you can't debate it. Lower CG means more control. It also reduces areodynamic drag.
BTW, I never scrape my undertray or any body parts of my car unless theres 4 people in my car and i slam the brakes just after i roll over speed bump. I've got a 1 finger gap in front and two finger gap in the rear (between the tire and fender).
Old Oct 10, 2001 | 02:21 PM
iroc5speed's Avatar
I love a slammed thirdgen, too bad I can't lower mine due to the fourth gen rearend. They look great and handle a lot better.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
