Drivers side tire rubs when turned full lock right -- Stock tire size
Old Oct 29, 2010 | 09:38 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I've been having a problem with my front wheels. On the drivers side, when I'm at or near full lock turn to the right, my wheel rubs on the sway bar/inner fender to the point you can see the wear marks. It's taken off the powder coating on my sway bar in one spot. I'm runnin 15" wheels with 235/60/15 stock size tires. The only threads I've been able to find on this are several years old and really don't answer my question. Any help would be greatly appreciated. Thanks!
Old Oct 30, 2010 | 12:31 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Drivers side tire rubs when turned full lock right -- Stock tire size
What is your alignment? I was running positive camber before and it rubbed on headers AND sway bars, but now that I have -1 degree of camber, it doesn't rub in those locations anymore.
Old Oct 30, 2010 | 11:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I am using the factory specs for alignment as it was performed at a local dealership.
Old Nov 1, 2010 | 10:14 AM
that's what i had too before when it was rubbing.. factory specs are crap IMO, they give you not enough caster and positive camber (for less tire wear it seems). I would get as much caster as possible (better straight line stability, but make sure caster on the passenger wheel is 0.5 degrees more than the driver's side in order to not wander towards the crown in the road), and have negative camber around -0.5 degrees for better performance in handling.
Beyond aside from that, I think the positive camber might be the culprit the your rubbing issue so changing it to positive may help, or it may not.
Old Nov 8, 2010 | 06:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Has anyone else had this problem?
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
