no traction ?
Old Oct 29, 2010 | 02:55 PM
speedfreak89's Avatar
Car: camaro RS
Engine: bbc 460
Transmission: T-5, 5 speed
Axle/Gears: gm 10 bolt 3:73
no traction ?
I recently swaped my 305tbi in my 89 camaro for a modified 454, the car has great power but i cant seem to get enough traction to make the car really launch and after the engine swap i cant set it any lower, any advise for a good launch ?
Old Oct 29, 2010 | 03:16 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: no traction ?
Have you done any suspension upgrade / mods to it yet? Or, moved some ballast into the rear of the car and over the rear end?
Old Oct 29, 2010 | 03:31 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: no traction ?
I wouldnt want to hook if the big block is putting down some decent torque. I would worry more if the T5 and the rearend would grenade first.
Old Oct 29, 2010 | 04:12 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: no traction ?
I'm with 84. Not getting traction has probably saved you so far. I helped a friend put 472 Cadi in front of a TH350 in a '70 or so Cutlass. It would almost lift the front off the pavement and was a total blast. For about two weeks. Then bye bye TH350. It's all about the balance. How are your brakes? Can't have all that go with no slow. Be careful.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
