brake fluid
Old Oct 12, 2001 | 01:40 PM
Going Slow Sucks's Avatar
brake fluid
Would flushing out the old brake fluid give new life to my brakes.Does brake fluid brake down after a while?
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Oct 12, 2001 | 04:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Brake fluid should be flushed and replaced roughly every two years. The problem is it absorbs moisture from the air. This moisture has a much lower boiling point than the brake fluid. See the link for more info on the subject. http://www.hotrodheaven.com/tech/brakes/brakes8.htm
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 14, 2001 | 08:42 AM
ede's Avatar
ede
i use valvoline synthetic. not sure it's any better but it seems to wrok as well as the regular kind. it's suspose to not take on water like the old but not sure. the dot 5 fluid is bullet proff as far as water goes but it cost a lot and you have to do a lot of converting to use it. i've only did it once on a vett and put stainless calipers on and the dot 5 fluid.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 14, 2001 | 02:01 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Stick to plain old DOT 3 brake fluid from a good brand (they're all synthetic).
Our brake system was designed late seventies,when DOT 3 was the best.
Using DOT 4 or higher CAN cause all sorts of problems,like swelling or dissolving rubber parts,it is also a well known "secret" that DOT4 and higher has "thicker" viscosity,causing again all sorts of problems.
And yes change it every two or three years no matter milage,the watter it absorps,can cause rust inside the brake system,also it will boil,when braking hard,causing the pedal to fall to the floor,NO brakes!!!
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
masonta
Sep 1, 2015 06:40 PM
