changing motor mounts with motor in car...
Old Oct 16, 2001 | 09:21 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
when i put my new motor in i didnt put y new motor mounts in. i basically was just being lazy and didnt want to deal with taking the old ones off. i am now kickin myself in the *** over this. how hard of a job is it to do without taking the motor out? i know this is a pretty stupid question, but i really have no experience in motor mounts at all. i plan on using the ES poly mounts. the reason that i want to do this is because my SLP headers are hitting the steering column, and i want to put a stop to it asap. thanks.
-Brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Oct 16, 2001 | 11:25 AM
86Chicken's Avatar
Use a bent 15mm wrench (might have to weld an extender rod on end for some) to get at the nuts in the frame. Lift motor a little to gain access to get upper bolts. Curse, swear heavily while trying to loosen and not loose parts in frame. Installation is reverse.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
**** Great cars aren't bought, they're built ****
Old Oct 16, 2001 | 01:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
If you like your hands and would like to keep them I wouldn't recommend changing the mounts with the engine in place. You would go down in one of those Darwin Awards postings.
Old Oct 16, 2001 | 02:17 PM
86Chicken's Avatar
Changing motor mounts with the engine in is not a big deal. Maybe good for a few hours if you have never done it before.
There is no real reason to take the engine out. Just make sure it is well supported so it doesn't fall.
I think that pulling an engine out is much more difficult than just bending a wrench and loosening a few bolts.
Dale
Old Oct 16, 2001 | 05:18 PM
Mark W. Winning's Avatar
I changed mine to the ES ones with the motor in the car. I did pull out the dist though. I did not want it bending on the firewall as I jacked up the motor.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Oct 16, 2001 | 08:13 PM
JPrevost's Avatar
Car: 91 Red Sled
z28 boy, I guess you didn't want to sell me those bushings .
When I changed the mounts it wasn't too bad but that was without the motor in. It isn't a big deal because the mounts are really simple and the only hard thing to get to is the nuts in the frame.
, Jon (350 TBI!)
91 Red My website
Old Oct 16, 2001 | 08:26 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah when i had the motor out, i looked at those nuts and was like, "no way in hell." my stockers werent bad...well they didnt look bad. but if there is a snowballs chance in hell that they will fix my header problem, ill try it.
-Brian
1991 Camaro RS
AIM - "Z28 Boy"
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
