what can i expect to pay to get my frame checked??
Old Oct 16, 2001 | 09:24 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, i know..ourars dont have a frame...but you know what i mean.
before i get my SFCs, i want to bring the car somewhere to make sure it is "straight".
i dont even know wher to begin as far as cost goes...i have to make some phone calls eventually, but i cant right now. anyone have any ideas?
-Brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Oct 17, 2001 | 02:02 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
At the body shop I work at as a frame repair tech the charge just to put the car on the machine and measure it is $300-350.Now keep in mind that is just hook up and measure not fix,fixing is usually an additional $65-70 an hour.Frame measure and repair is not cheap.Rates where you are could be cheaper but this is just from my own experience.Shop around and maybe you can find it fairly cheap.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Dec 2, 2003 | 12:58 AM
25THRSS's Avatar
is it really that expensive just to have it checked?
Old Dec 2, 2003 | 06:23 PM
3rdGenBlackBird's Avatar
Is there any easy way to check it ourselves?
Old Dec 2, 2003 | 10:01 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I had slight frame damage when I wrecked my car and I got the front end pulled out for 178 bucks. This was not a back yard shop either. I geuss it is pretty easy to do. I would say be prepared to pay 150 to 400.
Old Dec 3, 2003 | 06:16 AM
ede's Avatar
ede
last one i had checked, actually fixed i knew it was damaged, was in the 250 range. it was a minor fix since i had already worked it back into place as best i could and all they had to do was do the finial tweeking. this was 2 years ago and it was sometihng like 175 just to put it on the machine.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
gta90
Sep 15, 2015 04:00 PM
Bryan F
Aug 27, 2015 07:28 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
