your expirence is needed
Old Oct 13, 2001 | 07:16 PM
90rsMustangkiller's Avatar
I plan on doing over a good portion of my suspension and i have a list of things i plan on buying. please tell me your expirences with the following products:
eibach pro-kit springs
KYB AGX shocks
KYB GR-2 struts
lakewood adj. panhard rod
lakewood conrol arms
Jegster Sub-frame conectors
Edelbrock tbi strut tower brace
thanks
90 RS 305 tbi, 4 3/4" cowl Hood, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, 3.23 posi, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension
Old Oct 14, 2001 | 08:38 AM
ede's Avatar
ede
i'd stay away from the jegs SFCs. never used them but have seen them i nthe store and believe most anyone elses would be better.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 14, 2001 | 09:48 AM
Bjase's Avatar
Car: 88 IROC
I've got the Edelbrock STB (mine's TPI) and the Lakewood adj. panhard rod.
The STB is a good piece. It ties into the cowl area, making things much stiffer than if it just went across the strut towers. It was the single best mod I've done, so far.
The panhard rod is also of good quality, but I was disappointed by its weight. Much heavier than the stocker. But my stock one was bent, and the Lakewood was the cheapest one I could find at the time.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Oct 14, 2001 | 11:14 PM
Ken88GTA's Avatar
I just installed the Eibach Pro-Kit and AGX shocks last week. The improvement over the worn out original parts is indescribable! The springs lowered the car just enough and corrected the "nose up" stance to a slight "nose down" stance which completely changed the look of the car. They also work well with the shocks , my handling AND ride improved drasticly! I like the adjustability of the AGX shocks, I'm still playing around but you can definitely feel the different settings. I can highly recommend both! I'm looking to Steve Spohn for my next suspension upgrade. Check out his web site before you make a decision.
Good Luck,
Ken
Old Oct 17, 2001 | 07:53 PM
come on i know more people have used this stuff
thanks
90 RS 305 tbi, 4 3/4" cowl Hood, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension
Old Oct 17, 2001 | 08:05 PM
j166a99's Avatar
my setup is somewhat similar to yours and i could see the thinking behind them.
here's my story:
-edelbrock LCA / struttower bar
-lakewood adj. panhard rod
-PST front&rear poly bushings /swaybars (1 1/4 front, 1" rear)
-belltech 2" lowering spindles front, 1.75 rear drop springs
-KYB struts/shocks
my car drives and corners like a CHAMP (ZERO body lean)! believe me! i've not yet tested G's, but i bet 1G skippad might be in order.
IMO, SFC are okay, but do the basics first (bolt on). if you still arenet satisfied with the feel, then go ahead.
any other ?'s shoot...
'86WS7
Ram Air...
*EiyseWhite*
italiano67
Dec 11, 2016 09:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
