Weird sound from the rear... What can it be???
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Hey,
A few days ago I starting hearing a weird sound coming from the rear end, hard to discribe the sound, it sounds like when a brake is sticking and it reverbs through the chassis ( I guess that is as close to describing it
. I have a 3.27 Posi rear.
I only here it when I take a sharp right turn. Left turns are fine and straight away is fine. I am sure it's coming from the driver's side. What could it be? I did notice that I am dripping fluid at the bottom of the inspection cover. Tuesday I am going to be pulling the cover to take a peak...could it be serious??? Could it be low gear lube??
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
"Better to look at it than to look for it
. I have a 3.27 Posi rear.I only here it when I take a sharp right turn. Left turns are fine and straight away is fine. I am sure it's coming from the driver's side. What could it be? I did notice that I am dripping fluid at the bottom of the inspection cover. Tuesday I am going to be pulling the cover to take a peak...could it be serious??? Could it be low gear lube??
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
" Thread Starter
Anyone? Need help
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
" Thread Starter
Ok...different twist in the problem.. tonight I took my car out for a drive...it is raining really hard and there is a lot of water n the roads. So I take the car around a large sweeping right turn ( an on ramp) and now the noise is not there any more! It was the same turn I took yesterday and the noise was there,,,only difference is that yesterday the roads were dry! What the hell is causing the noise!! ARRGGGHH..
If it was a wheel bearing or rear end problem wouldn't the noise be there regardless of water on the road??
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
" Senior Member
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
87 rocz, I think I am having the same problem as you.
From what I am guessing, it's either the diffrential, or u-joints. Hasn't rained much here, wonder if that would make my problem go away too. hmmm...
Still, I had my axle bearings replaced about 8 months ago, which stopped this problem almost entiely, but now it's back again. Im not sure if that means that was the problem, and they are already worn out again or not.
My rear tends to do the moaning when i hit uneven roads, or am making a u-turn the the left.
Sorry, wish I had more information! Ill post again once I can afford to have it looked at.
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
you guys make sure if you have limited slips get the GM limited slip aditive for the rear and put it in the fluid. Also make sure you have enough fluid in there. This sounds like the same problem a friend of mine was having.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
