SFC's which ones will bolt on and clear twin cats and edelbrock headers?
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i plan on bolting them on then welding after.. i am lookin at the jegsters for 180$ but do they clear twin cats
white/gold GTA ,leather new 5.7TPI ,S/R torker 2.02 1.60heads comp cam 212in 218ex dur. .475in .495ex lift. edelbrock headers ,dyno 2000 says 337 hp 405ft lbs of tork..700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
i'd stay away from jegster stuff, i doubt if they clear twin cats either. also i wouldn't bolt them on, maybe a sheet metal screw to hold them in place to weld but not for a permanate or semi permante connection.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 89GTA
Axle/Gears: B/W3:27
so if u say stay away... then which ones will work with twin cats???r the jegsters junk?? coz with my mods i feel it is a good idea to get them.
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Lingenfelter sells Double Diamond frame connectors for $229, the offer added support due to 2 additional mounting points per side (1 at trans crossmember & one at rear in addtion to front & rear frame rails) & also connect in the middle, & designed to clear dual cats. Also, Kenny Browns are about $180 w/ 1 additional mounting point @ the trans crossmember & will also clear the dual cats.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Steve Spohn offers 1 design for single cat exhaust and 1 design for dual cat exhaust. Plus, they have an extra brace on each side to really stiffen up your chassis. I think they are about $180. www.spohn.net
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
