Alum engine parts, now she's sitting too high up front...
Old Oct 19, 2001 | 12:11 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I took off the air pump stuff, put on a set of aluminum heads, and an aluminum water pump. I figure that's about 100 lbs off the front. I had the engine out for about a month, and since I put the engine back in a week ago, the front is sitting almost an inch higher than it used to. I don't have it running yet, and the hood isn't on either. Will the springs settle once I get this thing back on the road? And if I put on a fiberglass cowl hood, how much more weight is that gonna take off the front?
Old Oct 19, 2001 | 01:22 AM
AntiVTEC's Avatar
Whoa, an inch? You have stock springs? Does it look normal again when you sit on the front? The stock hood is very heavy, and a fiberglass hood will only contribute to your front-high problem.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si, 94 MR2 non-turbo.
Old Oct 19, 2001 | 01:28 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Naw, I got Eibach sportlines. I tried sitting on it, bouncing it, etc. And even at 120 lbs I know I weigh more than that stock hood. I heard somewhere that I'd only lose 20 lbs for a cowl hood.
Old Oct 19, 2001 | 02:52 AM
Tas's Avatar
Tas
heads 40 lbs, water pump 8-10 lbs. fiberglass hood 25 lbs off.
Old Oct 19, 2001 | 03:57 AM
TA88GTA's Avatar
1 inch! sh*t I'm doing the same mods. Oh well looks like it's time for some new springs (still riding on the stock ones).
Your car should settle a bit once you take it for a spin but I dont know about it settling an inch.
Old Oct 19, 2001 | 05:49 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
For a more accurate picture of how high it will sit up in the front you'll have to roll it a few feet back and forth a couple of times so that the suspension will settle into its normal position. For a 100 lb weight loss up front I'd expect a ride height change somewhere between +3/8" (with Z28 springs) and +5/8" (base model springs).
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old Oct 20, 2001 | 05:12 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I found the same on my 89 RS ZZ4TPI. I cut the stock RS front coils (one coil) and the ride height is perfect with my Jamex rear springs. I had what I thought were front springs for a 3rd but they were actually for a 4th gen. I know have the correct Jamex fronts but no spring compressor to put them in.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 23, 2001 | 09:01 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
try rolling it forward and backward a bit. When I jack up my cars my front tires don't fully settle till I move it. Just an idea.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Azrael91966669
25
Jun 20, 2017 04:04 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
MENINBLK
Aug 5, 2015 11:58 PM
