32mm to 36mm sway bar worth it?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I currently have a 32mm front sway bar on my car (24mm rear). Would I see any improvement by switching to a 36mm front bar, or would the difference not be worth it?
Guest
Posts: n/a
Re: 32mm to 36mm sway bar worth it?
Yes in your case it should be worth it. (I looked at your sig of modifications) You will definately notice a difference. The body weight of these cars have a certain roll percentage when compared to the roll factor of the suspension design. the 36mm bar is really beneficial up front. Keep a smaller bar in the rear if possible, but I see you already have the larger 24mm- so you definately need the bigger 36 to help match cornering balance. What you also wantto do (against what many people will tell you wrongly) is to get your rear LCA's parallel to the ground with you in the dirvers seat. I see you have LCA RB's, if you have listened to others and bought these thinking you need to drop the rear mounts of the LCA''s to the lowest setting you are probably hurting yourelf here unless the car is extremely lowered with lots of rear supension travel (soft rear springs and shocks)...again- make sure those rear LCA's are parallel tot he ground aproximatly (probably will never be perfectly parallel, just get them close as you can.)
Car: 86 Trans Am
Engine: 408 stroker sbc
while its apart, dont forget a good set of endlinks and bushings for the sway bar.
see what the car does after the install, you may find the rear bar to be too much for the car.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've never heard of a factory equipped 32/24 combo on an IROC.
JamesC
JamesC
Car: 85 Iroc-Z
The car already has a set of energy suspension end links and sway bar bushings on the bar. I don't know if the bar has been changed or not, but it is a 32mm front 24mm rear combo. Would there be any cons of switching to the larger 36mm bar, or would I only improve with the swap?
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
get the 36, that 24 rear isn't a good match for a 32.
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
85iroc - I'm surprised that you aren't already complaining about the car being a little tail-happy. Power mods, front suspension mods to make that end stick better and rear suspension mods that sacrifice a little rear lateral grip tend to make a car easier to get the tail to come around on corner exit.
Norm
Norm
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Just a little info. Approximatly every 4mm increase in bar size will double its rate. Even though a solid bar will be stiffer then a hollow bar the outside diameter plays the biggest role in determining it's twisting resistence. Needless to say a hollow 36mm bar is much stiffer then a solid 32mm bar. There is a sway bar rate calculator someplace on the web.
Car: '08 Mustang GT
Engine: 4.6L
Doubling the rate of a solid bar takes 19% bigger diameter if everything else remains the same (1.19 = fourth root of two).
To compare a solid 32mm bar to a tubular 36 mm bar you really need to know the ID of the 36. Typically, ID's of one-piece tubular bars are around 70% to 72% of the OD (wall thickness ≈15% of OD). That puts a tubular 36 about 20% stiffer than a solid 32.
Norm
Norm
Car: 85 Iroc-Z
Thanks for the info. The rear off the car does feel like it gets real light when conering at higher speeds. I would imagine that the 36mm bar should cure some of this.
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
I may be wrong but i think the 24mm rear sway bar came only on 1LE car.
and 23mm only on G92 option car.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
36mm is an improvement from the 32mm, did that upgrade myself 20 years ago.
As others may suggest, there may be no easy rear sway bar choice for an f-body. Different springs, weight reduction, and weight of the rearend itself will contribute to a choice of rear sway bar.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My 86 IROC had 34/24 combo, stock. Poly end links and bushings will help too!
