Do Bendix pads resurface rotors?
Old Nov 1, 2001 | 10:12 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I bought some OEM Bendix pads today and the guy at the counter said they have lines on the top of the pad that resurface the rotor so they don't need to be turned, is this true? It kinda sounds far fetched to me buy you never know.
1989 Formula 350
Old Nov 2, 2001 | 02:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like BS to me.
Old Nov 2, 2001 | 09:49 AM
Ben87GTA's Avatar
Wow. I grew up in valpo. small world. no input on the pads. sorry
Decently worked 87 GTA; finally got a good time out of her: 12.72 @ 116.4mph
other toys: 2002 Yamaha R6 , and a 97 Supra TT
Old Nov 2, 2001 | 10:24 AM
Fastcamaro87's Avatar
no they dont resurface the rotors, thats a load of BS, u should call the same guy up and tell him you need front drum brake shoes for an 83 corvette, thatll really throw him off especially if hes a new guy
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 3, 2001 | 02:22 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
BS
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 5, 2001 | 12:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are those the MKD-154's? That's what I use! Anyway, the Bendix pads are coming with a coating that is supposed to help the pad-break-in process. Of course, they still recommend a long & gentle break in, so who knows if that stuff is worth anything.
I think they call it a titanium coating? Whatever it is, it's meant to ease pad break-in. If ya look, the part of the pads that touch the rotor will look more silverish/grayish as opposed to a semi-metallic pad that's been used.
-Tom P (Hot rodded 1986 Firebird 2.8l)
[This message has been edited by TomP (edited November 05, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
Vintageracer
Sep 24, 2017 12:34 PM
86IROC112
Nov 7, 2015 06:50 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
