Need rear disc brake line fittings , where do I get them?
Old Nov 4, 2001 | 10:52 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
My car is an origional disc car that I had drum brakes in temporary. I just bought a disc rear but the guy would not part with the brake lines. Can I get these parts at a parts store? I need the hookups to the calipers. The drivers side needs a black boxed shaped connector. I don't know what to call it. The junkyard is closed today and I need the parts. Can anyone help me out here? Thanks
[This message has been edited by IROC315 (edited November 04, 2001).]
Old Nov 4, 2001 | 03:05 PM
ede's Avatar
ede
yep try just about any parts store they should have what you need.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 5, 2001 | 12:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you want new brake lines for the axle, check out http://www.classictube.com - they have 'em in original OEM steel and stainless.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 5, 2001 | 05:26 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I recently rebuilt a posi disc-brake rear for my 92 RS,and have had a hard time finding the flexlines that connect the calipers to the hardlines.Eventually, I figured since I had braided stainless lines up front and between the rearend and chassis,that I'd just make my own.
Aeroquip and Earl's both sell everything you need to make custom SS flex lines for just about any application.
Try:
http://www.RACEHOSE.com/
or,
http://www.anplumbing.com/
I've bought a lot of my plumbing from these two vendors and have been very satisfied.It's not inexpensive to convert to the braided stainless/teflon hoses, but you'll only have to do it once!
-Rich-
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
novaderrik
Aug 10, 2015 12:44 PM
