Not low enough.
Old Nov 5, 2001 | 07:22 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
Not low enough.
I looked for a similar post but found nothing. I recently put 1.5" drop springs on the front of my TA. I found after they were installed that the car was only about 0.50 inches lower. The guy at the shop said it's because my stock springs were so old that they had sunk down and it didn't look any lower. But I think that is BS because my cousin put 1.5's on his camaro and he has no fender gap. We both have 16" rims and the same tires, and I have about an inch and a half fender gap. What's up with mine? I also have rubber busings on top of my springs that are about an inch thick. Do you think if I removed them it would make a difference? Will no bushings be bad?
Old Nov 5, 2001 | 08:38 PM
nicmike85's Avatar
Different spring manufacturers will have different heights. If you remove the rubbers then you will get alot of road noise and the springs may move around making clanging noises. Find out what springs your buddy has, get a set, and sell yours.
Old Nov 5, 2001 | 08:46 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Some springs will compress and settle lower with time
mine did about 1/2" in about a month or so
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Nov 5, 2001 | 10:39 PM
AntiVTEC's Avatar
I went through your same delema man. What kinda springs did you install?
I put sportlines in my car and it dropped a bit. The front more than the back definatly. I wasnt satisfied so I went ahead and pulled the rubber bushings out. Guess what, there was no noticable increase in road noise at all. And on top of that, the front came down another 1/4 inch and the back 1/2 inch!
But, before you pull your bushings out, check to make sure the springs were installed right. The end of the coil on the fronts should be on the inside of the A-arm, closest to the motor. See what i'm saying?
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si, 94 MR2 non-turbo.
My Car
Old Nov 6, 2001 | 12:54 AM
Ben87GTA's Avatar
Or just do what i did and install 2" drop spindles, then 1.75" springs.. give it a nice slammed look.. and i can still make it over speed bumps. well.. MOST speed bumps
Decently worked 87 GTA; finally got a good time out of her: 12.72 @ 116.4mph
other toys: 2002 Yamaha R6 , and a 97 Supra TT
Old Nov 6, 2001 | 04:07 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
I was thinking about the drop spindles, where did you get yours and how much? They don't look like they'd be to hard to install, but that's just an opinion. How long did it take you to put yours in? I think I might take out the rubber bushings first. If the spindles aren't to much hassle I might go with them too. Thanx.
Old Nov 6, 2001 | 08:52 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I ended up removing the rubber isolators and chopping 3/4 coil off my Eibach springs.
After I had it low enough, I needed caster/camber adjusters to keep it from going through front tires so fast.Drop spindles seem like a good alternative.If I had to do it again,I may have done it differently.
-Rich-
grngryoutmyway
Oct 18, 2016 05:48 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
327IROC85
Sep 23, 2015 12:11 AM
