Baer Braking Systems
Old Oct 30, 2001 | 04:08 PM
CamaroMike's Avatar
Is anyone using one of their front systems and and what size (12 or 13 inch rotors) are you using.
Also FYI, Baer sells a rear drum to disc conversion for our cars, about time!
84 Camaro ZZ4 with HOT cam. Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (Best 60',Quarter Mile, MPH) (1.88, 12.91, 106.77)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Nov 5, 2001 | 10:29 AM
scauffiel's Avatar
I'm using the front Track system from Baer. Did you have any questions or just taking a poll?
Steve
EDIT: I suck - I'm using the 13" rotors with aftermarket Mercedes rims.
Steve's Trans Am Temple
[This message has been edited by scauffiel (edited November 05, 2001).]
Old Nov 5, 2001 | 02:29 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
it would be nice if they would reply to the frikn e-mail i sent asking for a quote.
Old Nov 5, 2001 | 07:40 PM
90FFBird's Avatar
They (Baer) are usually a little slow to respond to e-mails for some reason. But the wait is well worth it. If you need a faster answer, just call them. They will send you a template to trial fit your wheels for clearance. The guy I dealt with was Bill Koppinger and was nothing but helpful. Each system is going to be set up to your needs/budget and is more or less custom. You should call and talk to someone if you're serious about buying an upgrade, reguardless of who you buy from. Do your homework, the difference in the car will be worth the effort. I used the 12" SS setup ft & rear with options. They look almost as good as they work =) and they look awesome.
Old Nov 5, 2001 | 07:53 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Is it true that with their 4 piston Alcon setup the spindles will need to be changed? I've either seen that on this board or it came to me in a dream .
Old Nov 5, 2001 | 08:49 PM
90FFBird's Avatar
I think the spindles get changed/altered with any of their systems because of the larger diameter of the rotors. Just about any increase in rotor size forces you to modify the spindles. I think Baer builds most ,if not all, of their 3rd gen system on modified spindles and use hubless rotors. If you send your old spindles back to them you get $150 core charge back. They have different caliper brackets depending on what diameter rotors you want. I think you can get 12, 13 and maybe 14" rotors depending on how deep your pockets are.... not sure about 14's though.
Old Nov 5, 2001 | 10:54 PM
CamaroMike's Avatar
To fit the Track system into my 16" Centerlines I would need a 1/2" spacer. I really do not want to use a spacer. Has anyone used a spacer and how did you like the wheel being moved out or did Baer make the spindle 1/2" offset inward to couter the spacer?
The Bowtie
Old Nov 6, 2001 | 07:10 PM
90FFBird's Avatar
The spindles I got from Baer actually moved the wheels out about 3/4"-1" farther apart. It didn't affect handling noticeably, but I get a little tire squeal at full lock. This really only happens at parking lot speeds so it doesn't mean much. I had heard others say that they got the same ~1/2 more width per side too, but with the factory wheels everything still fits fine. You might be fine with the spacing you have if the centerlines have a little more offset than you really need.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
zayne0
Aug 24, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
