front coil spring question.
Old Nov 21, 2010 | 10:24 AM
mean57's Avatar
Car: 87 gta
ok a friend gave me new in box springs that were for his regular firebird v8 305 can i use for my 1987 gta? my question is about installed height not free height.
free height for stock is 13.01in.spring rate 649 lb\in
free height for for new is 14.88in. spring rate 421 lb\in
now both springs are applications for thirdgens.
will installing these change front ride height from what my gta is now?
if yes or no is the answer.. an explanation would be en lightning
thanks, mean57
Old Nov 21, 2010 | 12:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: front coil spring question.
it could, but would be hard to say, has a lot to do with weight.
the new springs is of a lighter rate, so it will compress more, but it taller.
just some quick basic math tells me that both springs should compress to a similar installed height with the same nose weight of the car, so the front ride height should/could be about the same.
the lighter longer new spring could help with weight transfer at launch, similar to a "trick" spring i believe.
Old Nov 21, 2010 | 12:41 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
considering that both are v8 springs the height shouldent be a problem. what you might run into though would be the rate being all wrong. if i remember correctly ws6 cars had a bit stiffer springs. so if you have thos rears you might find the tail of the car comming around more than you like.
Old Nov 21, 2010 | 12:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
exactly. i personally would stick with the heavier springs
Old Nov 21, 2010 | 07:55 PM
mean57's Avatar
Car: 87 gta
good answers thanks. if they have the trick spring result i would actually be happy. the cars is made for straight line. so turning isn't a concern of mine it'sa third car of mine gets maybe 2,500 miles a year.
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
Bryan F
Aug 18, 2015 02:28 PM
TA8487
Aug 11, 2015 09:02 PM
