Crashed car...please read
Old Nov 7, 2001 | 09:56 AM
camaro6spd's Avatar
ok,I amnotsure what happened but i tried to avoid dear and ended up hitting a huge rock that ws half burred int eh ground and taking out a mailbox. Now i think i pushed the drivesside wheel back into the the fenter ****ed up the drives side of the nose and 1/4 panel. I took a quick look at it this morning and the strut towers are inline(or so they seem) and so es everything eles in the engine compartment. I think i just fed upt he lower control arm. Now what would be involved in fixing this. I will repost more info buy 5 tonight.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 7, 2001 | 10:17 AM
camaro6spd's Avatar
ok, i found 4 camaros for sale that i can use.....
1) 1983 Camaro Z28 black/black 5 spd/new steering box, brakes, rotors, drums, whel cly, springs, parking brake, cables, grant GT steering wheel, Asking 800
2) 1991 camaro RS V8, auto, pw, t-tops, tint, 117miles, body and engien good, trans slips 1200
3) 1987 camaro auto OD, 305 carb, damage rear 1/4, asking 650.
4) 1985 camaro v6 auto, white exterior, red interior, sonly explode speakers, tires have 85% left, great car, good on gas, yet quick.
sorry for the spelling but i am nervious and the keyboard is ****ed up.
AIM: IROC 5spd
[This message has been edited by camaro6spd (edited November 07, 2001).]
Old Nov 7, 2001 | 10:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could've also bent the spindle (aka "steering knuckle") on that side, along with some of the steering parts (center link). I did that when I hit a curb. I used a steering knuckle out of my old parts car ('84 Firebird). You can see the spindle if you take the wheel & brake rotor off. It holds the rotor, and is connected to the balljoint in the lower control arm and the outer tie rod end.
You might've ruined the strut, too.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 7, 2001 | 02:10 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
hey,
It sounds like you're looking for a new car to put your tranny into (or even more of your car, the tranny just comes to mind since it probably cost more than any of the cars you listed)
I'm a little biased but I would go with one of the first two. You don't want the V6 car and you don't want the one with the fubar 1/4. (this is all imo)
The RS sounds like the best deal to me because you can just slip all your stuff into it. Plus it's the most desireable (most popular anyway) bodystyle of thirdgen right now and probably always. If you get the '83 Z you'll have to change over the pedal setup (you'd have to in the RS too) because it's the mechanical linkage.
If you get that '83, email me and I'll buy some of the parts you take off of it!
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Nov 7, 2001 | 04:46 PM
camaro6spd's Avatar
naa, i am gonna total out my car....it si all f'ed up, took a close look at it. I plan on buying something like an RS that is around here, it is a 305 5 speed with 110 miles and run around with that untill i get to money to pull the TPI motor out of my IROC, the 9 bolt rear, and all the other goodies. So it will be a while without the Camaro, this is kind of a mixed blessing...
Old Nov 7, 2001 | 07:43 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
My car is for sale if you are interested E-mail me.The interior is in good , there is a new headliner in it, and I tried to replace any of the piece that where cracked, I added a over head console from a iroc and a 145 mph speedo, I have changed every sensor and relay in the car, just I would not run in to any problems, The car is ready to be driven daily with no problems, everything is new all of the suspension is new everything. The rear has about 30,000miles on it the tranny has about 10,000 miles on it and the motor has less then 3,000 miles on it.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
E
Old Nov 8, 2001 | 04:09 PM
Xenodrgn's Avatar
Hey Camaro6spd, sucks about your crash. It's a beautiful car...
I don't suppose you wanna get rid of your rims? (providing none got messed in the crash) I'm looking for a set of 16 X 8's but I don't wanna pay out the a$$ for new ones... gimme an e-mail with a price if you're interested in selling.
hydrafire@yahoo.com (the one in the profile will work as well.)
Old Nov 9, 2001 | 05:29 PM
camaro6spd's Avatar
sorry, i already promessed then to a friend for a little bit of $$. I would LOVE to buy your IROC but I need to get cash and hold off, the car was not a primary car so it is allright for now. Later on down the road I will be selling the 145 dash cluster with the oh so rare 5500 redline, the black interior with NightRider seats(unless I want that in my 91-92 camaro(if so then I will still sell the NightRiders), the T-Tops(both sets if it is a hardtop), now if the 91-92 is TPI then I will sell my 87 TPI setup, if not I will put the 87 setup in the 91-92(kind of hard to find a 5 speed TPI). And anyother parts, so if you want stuff like this just set me an e-mail but I will not start to part it out untill I get another car(not for a while )
just post you e-mails and I will tell you guys whats goes when the time comes..
oh also the 2" lowering springs will be sold also. I am keeping the poly bushings and the huge aftermarket sways
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
dementednut
Sep 10, 2015 09:50 PM
IROCtometal
Sep 9, 2015 10:01 AM
