WS6 or not?
Old Nov 1, 2001 | 07:59 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
WS6 or not?
on saturday i am going to test drive an early 80's trans am, hopefully trade my camaro for it. my question is, inside on the dash on the passenger side, it says "high performance suspension" or something like that. how can i tell if it's a WS6 or not?
Old Nov 1, 2001 | 08:20 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I think that the size of the sway bars is enough. If it has a quick ratio steering box and big sway bars I wouldn't really be concerned if it were a ws6 or not.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 2, 2001 | 01:28 PM
85transamtpi's Avatar
Look at the wheels and sway bar. I think the "Performance suspension" logo on the pass side storage flap indicates a WS6 car. I know mine is a WS6 car, and it has that logo. You should also notice by the way it drives
peace
Old Nov 3, 2001 | 12:55 AM
ChevyGuy87's Avatar
Engine: 4.0
well, i talked to the dealer today, and it seems that the person who traded in the car wanted to take the Edelbrock manifold off, so he took the distributor off. then he thought that that was too much work. so he left the manifold, and put the distributor back in, but on the wrong tooth. the engine doesn't start so i won't be test driving it. i have a friend who is giving me a 350 so i don't care about that engine, i just need it to run long enough to get it 7 miles down the street into my yard. any one know of an easy way to realign the distributor on a SBC?
Old Nov 7, 2001 | 04:32 PM
89 4Mula 350 Tbi's Avatar
The grease ball way of doing it is switching around the spark plug wires on the cap
Old Nov 10, 2001 | 10:59 AM
MotorCityMuscle's Avatar
What the map pocket flap says doesn't mean ****. My friends 2.8 Firebird said that on the pocket-obviously not a WS-6 car. What year is the car? Most Trans Am's after 85, all Formula's(IIRC) and all GTA's will have the WS-6 package. If you want to be sure, check the little storage compartment on the driver side in the trunk area. The RPO code list should have WS-6.
Old Nov 10, 2001 | 11:11 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
If you really want to know... just open to center console and look at the RPO code sticker if it has WS6 it has the performance package. Also if it has G80 that means it has a positraction (limited slip) axle.
Or at least thats where my RPOs are listed in my 90 formula.
[This message has been edited by fireturd350 (edited November 10, 2001).]
Old Nov 10, 2001 | 11:41 AM
ChevyGuy87's Avatar
Engine: 4.0
it's an 85. im going there with my dad in an hour to look at it, might be coming home with it. i'll check the RPO list while im there. does anyone think im crazy for planning on swapping an engine outside in nov-dec in massachusetts?
Old Nov 12, 2001 | 05:35 AM
bzznczzn's Avatar
All Formula's come with the WS6 package?
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
dbrochard
Sep 7, 2015 09:41 AM
neekolzun
Aug 24, 2015 04:59 PM
