Rear End Calipers
Old Nov 13, 2001 | 04:24 PM
matty350TPI's Avatar
Rear End Calipers
Ok so I have a 9 bolt with pre 89 calipers (the ones that have the screw out parking brake) anyways providing I don't sell my car I will be trying to put the updated calipers on it and I was wondering if they would just bolt on to the old backing plate? Or do I need to find a backing plate made for the newer calipers? Any ideas? Thanks
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque out of the box
5speed, Centerforce clutch, Spohn Sub-frames & adjustable pan hard rod, Jamex 1.5' Lowering springs, 2 1/2' Exhaust,ram air setup, ported and polished plenum, soon 3.45 9 bolt rear end with discs!
Old Nov 13, 2001 | 08:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What do you mean by "updated" calipers? Do you mean the 89+ aluminum PBR calipers? If so, then you'll need to change the backing plates. They'll have to come from a wrecker too, 9 bolt backing plates for PBR calipers are no longer available from GM.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
