parking brake q...?
Old Nov 18, 2001 | 01:04 AM
breathment's Avatar
parking brake q...?
Ok, my parking brake is either stupid or rusted. whenver i use it, and release it, it still holds, and i have to get under and jiggle the cables to get it to release, so i never use it. my question is how hard is it to replace? and i thought my uncle told me i would have to get it at the dealer, cause he thinks autozone doesn't carry it, (he used to work at autozone). also, the rear brakes adjust when u use the parking brake right? i remember hearing that GM screwed somethign up and u have to make an adjustment for this to happen correctly. is this true?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 18, 2001 | 03:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Parking brake cables should be available at almost any parts store. They don't take long to replace. The parking brake does adjust the rear brakes if you have discs.
If you have 82-88 rear disc brakes you may have the bad calipers which must be rebuilt or replaced to fix the problem.
Old Nov 18, 2001 | 08:31 PM
breathment's Avatar
so can 89 rear calipers be put on an 88?
- David
Old Nov 18, 2001 | 08:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nope...
Old Nov 18, 2001 | 09:12 PM
breathment's Avatar
hmm, well aren't 89's aluminum? so is there anyplace that makes aluminum calipers for 88? even if the cast ones will work
- David
Old Nov 19, 2001 | 12:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you change the backing plates, you can mount newer calipers on an older rear end.
Old Nov 19, 2001 | 09:52 AM
FiReBReTHa's Avatar
Whats the mod you have to make to your P Brake for 4th gen rearend? because im goin manual and with a remote start so i cant leave in gear all the time.
Thanx. ill get pics of install
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
