Panhard to body brace??
Old Dec 3, 2010 | 11:16 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Theres two parts to our panhard bars i never see anybody advertise the body bar. do they make this after market i have never seen it??
Old Dec 4, 2010 | 01:50 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Panhard to body brace??
Granatelli made one, it was basically a stock piece that was somewhat modified, powdercoated and didn't fit
I doubt you'd see any improvement from an aftermarket piece, you're better off welding & gusseting the bracket on the frame that the bar is supposed to support
Old Dec 4, 2010 | 02:07 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
http://www.bmrsuspension.com/index.c...&productid=371
However, that lowers the mounting points which I think will screw with roll center/roll axis.
Old Dec 4, 2010 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Avoid the Granatelli piece. Here's my review:
https://www.thirdgen.org/forums/afte...r-panhard.html
JamesC
Old Dec 4, 2010 | 11:13 AM
Engine: 350TPI
Wow for all the Sh$T you have to go thru i think ill leave it. i dont understand why somebody just dosent make a tubular one that fits stock points.. insane.
Old Dec 4, 2010 | 11:16 AM
A tubular one wouldn't fit, it would come into contact with the panhard bar itself
Old Dec 4, 2010 | 11:28 AM
Stephen's Avatar
Car: 87 GTA
The stock piece is u-shaped for the PHB to fit in, during its arc movement.
It would hafta be 2 tubes, so that there was room between the 2 tubes, for the PHB to fit. So at that point, you'd be adding unneeded weight with little to no strength benefit.
Old Dec 5, 2010 | 01:51 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I boxed my OEM piece years ago.No issues with the tubular PHB to date...Cheap upgrade.
Old Dec 6, 2010 | 04:28 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Not sure buying an aftermarket one adds any value except if ou decide to run a dual 3" exhaust.
Buy a panhard rod and call it a day.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Kenwood
Sep 4, 2015 05:50 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
