Search for Sway Bar Bushings for 36mm Front Sway Bar
Old Nov 20, 2001 | 10:10 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I can't find anyone that makes poly bushings for my 36mm front sway bar. My car is equipped with the WS6 performance handling package. Any help would be appreciated. Mark
'89 Firebird Formula-
K&N Air Filter, Holley Throttle Body Air Foil, Hotchkis Strut Tower Brace, Hotchkis Panhard Rod, Hotchkis Trailing Arms, Kenny Brown Subframe Connectors, GT Auto Assesories aero wing, steering brace
It's mind over matter. I don't mind because you don't matter.
Old Nov 20, 2001 | 10:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try Guldstrand.
Old Nov 21, 2001 | 11:22 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I used 35mm ES ones on my 36mm bar. the fit was perfect. The set I had to get them from was like a 1 ton dulley or something like that.
Old Nov 21, 2001 | 01:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The GM 1LE 36 mm bushings, while not poly, are of a higher durometer than regular bushings. I suspect these were stock in your car.
JamesC
Old Nov 21, 2001 | 02:16 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Guldstrand is the only place I know to offer aftermarket ones.
Old Nov 21, 2001 | 02:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you might try e-mailing steve spohn, i know his swaybars are that size, and they come with bushings... just a thought
Old Nov 21, 2001 | 04:13 PM
Shox.com's Avatar
Call Dave Turner Motorsports at 800-854-6640
or email them at speed@daveturner.com
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
