Say I go to a junkyard, and find the dual-piston front calipers...
Old Nov 20, 2001 | 12:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
...am I correct in assuming I need the following from the junkyard car?
1. Calipers
2. Spindles
I'd buy new hoses and pads, of course! Do I need anything else (like rotors or prop valve)? What did those calipers come on, anyway... just trans am's and z28's?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 01:06 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
You will also need the rotors & wheel bearings,but those you can also pick up at local parts store.Assuming you have disk/drum right now,you can use your existing prop valve and master cylinder as long as they are in good working order.These calipers only came on 1LE equipped F bodies,which are extremely rare to find in a junk yard anywhere.You will have a better chance finding the parts used from on line f body places that part them out or buying them all new (like I just did to finish my front upgrade).Good luck,you will need it for this one.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Nov 20, 2001 | 01:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I actually have 4-wheel-disc right now... the rear calipers are rebuilt '84 units. I know it'll be a tough find, but my friend has a friend who knows of some obscure junkyards, we were talking last night of visiting them just for the hell of it over Xmas break. I wanted to be sure what I should pull from the car if I stumbled onto a major find!
Thanks!
Old Nov 20, 2001 | 04:45 PM
FiReBReTHa's Avatar
SHOPPING LIST!!!!
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Nov 21, 2001 | 01:09 PM
gravitar's Avatar
hell if you find a car at the yard with dual-piston calipers, i'd say you should take the whole car and figure out what you CAN'T use afterward
Old Nov 21, 2001 | 06:22 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
If you find a 1LE car in a junk yard.Take the entire car home.Put it back together somehow.It will then be worth more than your car that you only wanted the parts for!
BlueIroc-Z
Jun 9, 2019 03:22 AM
blackd-out z28
Aug 15, 2015 08:18 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
guy76767
Aug 6, 2015 05:58 PM
