RPO code question
Old Nov 24, 2001 | 11:40 AM
Steve's Avatar
Car: 91 Z28
RPO code question
I have a 91 Z28 camaro. I was wondering what is the size of the front and rear swaybar for option code. ( FE2 : SUSPENSION SYSTEM, RIDE HANDLING ). also if you know which springs go with that. Last part if any of you have the same information for FE0, FE1, FE3, FE7. Sorry if my RPO codes are off.
Thanks,
Steve
Old Nov 24, 2001 | 12:00 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey Steve. Look a little further down the board. I listed all the sway bars and their sizes 2 days ago. You should have the 36 mm front/24 mm rear setup. Springs vary from car to car, but if you poke your head under your car the springs should have a tag or a label on them which have the spring rate code on it. Post what you find and I'll get back to you.
hectre13
Dec 11, 2023 08:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
