installing shocks/struts
Old Nov 26, 2001 | 10:58 AM
thenewguy's Avatar
just wondering if anyone can give me some pointers on installing shocks and struts, and whether i can even do it at home, or do i need to take it to a shop to get done? anywhere that i can get some good instructions or anything?
86 Sport Coupe
V6 2.8L 173 CID LB8
no mods...not yet
www.geocities.com/tommyscamaro/index.html
Old Nov 26, 2001 | 02:22 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I recently installed shocks. I had to take out a few trim panels to get the carpet to come up over the top of the shock. Otherwise it was pretty easy.
Old Nov 26, 2001 | 02:27 PM
thenewguy's Avatar
well that doesnt seem too difficult then, and the front should be as easy, considering theres no interior to worry about...
86 Sport Coupe
V6 2.8L 173 CID LB8
no mods...not yet
Old Nov 26, 2001 | 06:33 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The only hard part about these is muscling/liquid-wrenching a couple of the tight, rusty bolts loose.
On the front (struts), the 2 lower strut-to-knuckle bolts are torqued to 195 ft-lbs, so hit em with WD40 or liquid wrench a couple of times a half hour before you try to get em out and maybe put some pipe over your socket wrench to get more torque to break them loose (and to put the new ones on).
The rear (shocks) are really easy, if you put your jack in the right place. To get at the top nuts, all you have to do is fold your seat forward and pull a bit of carpet up. That nut isn't even tight or anything.
If you're unsure about how to do it... buy a service manual (even Haynes spells it out pretty well). If you're "handy", don't pay a shop to do it - it's not that hard.
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
180* stat
Exhaust is next!
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
