Suspension questions
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
LCA's, relocation brackets, panhard rod.
What exactly do these do? Do they need better shocks and springs to really work?
Please pardon my ignorance.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
ORIGINAL OWNER
Performance:
Sights & Sounds:
LCA's are the arms that go from the car to the middle of each axle tube. The control up/down front/back movement of the rear suspension.
Relocation breckets are used to correct the geometry between the axle andt the LCA's whent the car has been lowered
The panhard rod controls the side to side motion(or lack there of)movement of the rearend.
Every suspesion piece on the rearend needs to be upgraded if you are serious about any sort of racing.
You have walked onto the biggest baddest dog porch and you will be dealt with accordingly.
I'd rather be historically accurate than politically correct!
Thanks for the reply.
When I stomp on the gas, the car's front end will raise up noticeably right before it goes forward. So by using stronger parts like the ones mentioned above, will it help reduce this "lift", thus making the car launch quicker?
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
No, that has to do with the front suspension.
The rear parts are more for rear wheel hop and control of tire spin.
Plus if you get the adjustable components, you can actually get a 4-wheel alignment on the car since you can not do that to a stock car.
Plus the relocation brackets help in traction even if you do not have a lowered vehicle.
13.2 @ 102.6MPH 60 degrees w/ still no tuning on motor
raven
Custom EFI Intake Setup
raven
Car: 82 camaro SC
The LCA relocation brackets will help in a non-lowered car. They will make rear of the car squat less when you launch. Or in some cases the rear end will actually come up when you launch--mine does.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
