Drum to Disc Conversion
Old Nov 30, 2001 | 12:22 PM
FT-LBS's Avatar
I just purchased a disc brake rear end from a 1991 Firebird. What do I have to change on my 1992 Camaro RS to make this work? Should I also get the proportioning valve from the Firebird?
1992 Camaro RS 5.0 TBI A/T
Most of the Bolt-On Mods
Old Nov 30, 2001 | 12:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, all you need is the prop valve. You should buy new rear brake hoses, too. Brake hose deterioriates over time, 10 years sounds like a good replacement time. If you want, you can buy the valve new from GM. This might also be a good time to flush your brake system of old fluid. Enjoy the swap!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 30, 2001 | 02:28 PM
Z28DJP1987's Avatar
Just bolt it on, the previous post covered what you need. Check the pads also.
Old Nov 30, 2001 | 07:57 PM
iroc5speed's Avatar
e-brake cables too
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
