tranny fluid in brake master cylinder.
Old Nov 13, 2001 | 08:37 PM
breathment's Avatar
what happends when ur friends grandfather puts tranny fluid (on accident) in the brake master cylinder of a 88 M*****g? can we just bleed all the fluid out till we see clean brake fluid in? or do we need to start replacing calipers and hoses?
spare the mustang jokes guys.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 13, 2001 | 09:56 PM
iroc5speed's Avatar
I think as long as it didn't get driven too many miles you should be fine as long as you get the system flushed and filled with new fluid. should not hurt too much.
Old Nov 13, 2001 | 10:43 PM
breathment's Avatar
i don't think its been driven any miles, oh well i guess tomorrow we'll have the answer for all the other people who experience this..
- David
Old Nov 14, 2001 | 09:45 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I don't know, but I saw my neighbor put motor oil in the power steering pump of his daughter's car!He was horrified when I told him there was a difference! He spent the next few hours trying to sponge it out of the resevoir with rags.
It'll probably be fine as long as you get it out of there before it gets driven.
-Rich-
Old Nov 15, 2001 | 10:54 PM
silver89Rs's Avatar
i think tranny fluid is petroleum based and if it is your friend better plan on replacing avery rubber piece in the brake system,(primary and secondary cups of master rebuild calipers and wheel cylinders) and anything else i forgot. he will need to do replace all the rubber parts because petroleum based anything weakens the natural rubber of the break system and can cause them to fail.
[This message has been edited by silver89Rs (edited November 15, 2001).]
Old Nov 16, 2001 | 09:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Brake fluid isn't petroleum based? I thought all hydraulic fluid was...?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 16, 2001 | 10:31 AM
SoCo80p's Avatar
actually way back in the day they used trans fluid in the brakes, i dont think it would do anything bad, i would just leave it, if it does have problems, then bleed out the system.
Old Nov 16, 2001 | 11:00 AM
iroc5speed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
actually way back in the day they used trans fluid in the brakes, i dont think it would do anything bad, i would just leave it, if it does have problems, then bleed out the system.</font>
I don't think it's a good idea to leave it...at least get it flushed and refilled with brake fluid. It's better to be safe than sorry when it comes to brakes...
Old Nov 16, 2001 | 03:16 PM
silver89Rs's Avatar
i know that brake fluid is not petroleum based it is silicon based. but the trans fliud is petroleum based and will destroy the rubber in the brake system. and cause the sytem to fail. putting tranny fluid in is just like pouring oil into your brake system, they will both devistate the seals
Old Nov 16, 2001 | 05:04 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
<font face="Verdana, Arial" size="2">Originally posted by RICH92RS350:
-Rich-
</font>
I know it's not advised but a friend has been using plain 50 weight engine oil in his powersteering pump in his 350 powered 85 chevy truck for the past 10 years because powersteering fluid leaks out too fast and he's too cheap to get it fixed,he says the engine oil stays in it a lot longer before he has to fill it back up, this same guy also has not changed the oil filter in the same time period either, he just adds oil when it gets low.I think the truck has about 200,000 miles and still runs like new!!
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Nov 18, 2001 | 12:11 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
if the trans fluid is just in the resevoir and the brakes havn't been pumped then you can probably just flush out the master cylinder, fill with clean brake fluid and then bleed the system out. while petroleum based fluid may damage the system I don't think such a small amount left for a short amount of time will hurt any thing.
Old Nov 19, 2001 | 03:12 PM
SteveSpohn's Avatar
Well, I'll be the bearer of bad news, you're in up the creek without a paddle. Every seal, cups, o-rings..EVERYTHING rubber is now screwed.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Nov 19, 2001 | 07:50 PM
breathment's Avatar
wut if the brakes haven't been used, and it still in the resovour? if we're still screwed, then do ya think junkyard parts would hold up?
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
Old Dec 2, 2001 | 09:12 PM
breathment's Avatar
top
Old Dec 2, 2001 | 10:18 PM
gravitar's Avatar
Although the ATF might eventually ruin the seals, I can't believe it would "kill on contact". If you flush out every trace of it, then you'll probably be fine. Just keep an eye on it.. if you start to get a soft pedal then by all means, replace the master cylinder.
If you only applied the brakes a few times, who's to say the ATF even made it down to the calipers? If any seals are destroyed, I would think it would be confined to the master cylinder, FOR NOW. Just make sure you bleed it ALL out!
[This message has been edited by gravitar (edited December 02, 2001).]
Old Dec 3, 2001 | 12:12 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
as stated before if the car has not been driven or more importantly the brakes not been pumped just remove the master cylinder. no damage has been done to the system since the fluid has be confined to the master cylinder. might as well replace the master while your at it.
Old Dec 3, 2001 | 08:55 PM
breathment's Avatar
ok, thanks alot guys, we're procrastinators so we still haven't gotten to work on it yet.
- David
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
LittleFranks
Sep 17, 2015 12:22 PM
Thornburg
Aug 25, 2015 01:46 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
