Cutting WS6 springs
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Cutting WS6 springs
If I get some used WS6 springs from the junkyard would cutting a half a coil off increase the spring rate?
I've heard that springs do eventually wear out, and I was wondering if doing this would be equivalent (or at least approximate) to buying new springs.
Also, would doing this affect the pinion angle to the point where I'd have to get LCA relocation brackets?
Any info regarding this would be really appreciated.
Thanks,
Mike
[This message has been edited by Fbird88 (edited November 30, 2001).]
Thanks,
Mike
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
WS6 springs have a rate in the neighborhood of 548lbs/in. Cutting ½ a coild will increase the rate by 10%, do you really want that harsh of a spring?
A standard (SC or RS) spring has a rate somewhere around 360lbs/in. Those would be a much better choice to cut.
Higher rate spring does not = better handling, just a more bone rattling ride.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
my springs are butter now after 165k miles. If I had better shocks it would ride just like a caddy (which it did before the shocks went out)
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Springs do not "wear out".
As they age they can get shorter (sag), meaning the car sets lower, but their spring rate does not change with age or from sagging.
Cutting them will increase spring rate though, and obviously will make them even shorter.
You could debate over the improvement or lack thereof that spring rate has to do with handling, but it definately increases ride harshness when you increase spring rate.
You don't "have" to get LCA relocation brackets if you lower your car, but you will lose traction if you don't.
If the body/chassis is lowered either by installing new shorter lowering springs, by cutting springs, or just by the original springs sagging over time, the angle of the control arms will change, moving the IC (instant center) forward, hurting rear wheel traction durring acceleration. The relocation brackets allow you to adjust where the instant center of the control arm is so you can tune for best traction/handling for your situation and needs. They are useful for the same tuning on non lowered cars too.
As far as relocation brackets go, it's not so much a "pinion angle" thing as it is a "control arm angle" thing.
To correct pinion angle an adjustable torque arm is the "thing".
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
[This message has been edited by IROCKZ4me (edited December 03, 2001).]
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
Car: 91 Firebird
Don't cut your springs, very bad idea. It can make them unsafe, they are meant to work the way they are. Spend a couple of bucks and go buy some aftermarket springs if thats what you want. Trust me I know form experience.
