loud pop\clang when wheel turned and reversing
Old Dec 4, 2001 | 10:32 PM
breathment's Avatar
everytime i have the wheels turned to the left and i am backing out, i hear what sounds like a single pop or clang about half way through backing out, or if i hit a bump or something, the other day i was backing out left and my front tires were going over a speed bump and so it was pulling the tires a bit and the pop\clank was really loud, and most of the time when im slowing down i will hear the noise again, just not as loud. it sounds like its coming from the front left. any clues?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 4, 2001 | 11:47 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I think its the tires rubbing the inner fenders but I'am not to sure. Mine did the same even with the factory tires so I wouldn't worry to much about it.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
Old Dec 5, 2001 | 03:59 PM
MD83Z's Avatar
Control Arm Bushings. Thats what makes all my front end noise. I need poly bushings and struts! probably springs. Everything for the back while w'ere at it.
Old Dec 5, 2001 | 04:49 PM
86IROCZ's Avatar
Sounds like ball joints to me!!
Old Dec 5, 2001 | 07:59 PM
breathment's Avatar
ball joints ehh.. how easy should it be to replace them? left and right? i know i will have to rent a puller\press from autozone, but with those tools how hard? and what exact parts do i need?
thanks
- David
RazorN8
Jan 7, 2022 11:44 AM
Fronzizzle
Mar 18, 2019 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
