Wheels shift to the right when i hit the brakes
Old Nov 22, 2001 | 10:17 PM
Camaro90RS43's Avatar
Hi i've been having this a problem with my 90 camaro, whenever i step on the brakes the steering wheel pulls to the right, does anyone have a clue why this is happening? Thanks for your help.
Old Nov 23, 2001 | 09:17 AM
82camaro's Avatar
Car: 82 camaro SC
stuck left caliper, pinched left brake hose, bad left brake hose.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 23, 2001 | 10:22 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
wow.. mine is doing that.. cept Im going
to the left.. I wished It was to the right
least your not heading toward the oncomming
traffic.. haha
something for me to get fixeed next
spring..
Old Nov 23, 2001 | 10:44 AM
LOL yeah last night i almost hit one of thoes traffic guys standing in the middle of the street, lol luckly when i stepped on the brakes i inched right, or i would have hit him. Thanks for the info, i'll have to get it checked out cause i just got all new calipers and replaced all my brake pads. wierd.
Old Nov 23, 2001 | 01:01 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I had the same (dangerous) problem.
Changed the front brake hoses(both L+R) with original new ones,problem solved!
Those hoses slowly disolve and get stuck over the years,so change them if they are like 10 years old!
Old Nov 23, 2001 | 03:00 PM
SoCo80p's Avatar
right once your car hits the 80-100,000 mile area most everything will need to be replaced, sound like forsure a seized caliper, mabey needs new shoes or mabey a line, most likely caliper, also a worn out front end will cause pulling.
Old Nov 23, 2001 | 09:42 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Its been documented a hundred times on this list. Its happened to me TWICE: Once at year number seven, and again at year number fourteen.
The brake hoses collapse on the inside and restrict the fluid flow. This is why your car darts to one side when you hit the brakes then straightens out.
Buy all three rubber lines: The two fronts and the one to the rear axle. Then, flush your brake fluid once every other year to rid the system of moisture.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Dec 5, 2001 | 10:36 PM
Bluebird's Avatar
Transmission: 700R
WHere could I get a set of stainless
steel brake lines for our cars?
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
jklein337
Sep 19, 2018 06:23 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
