who makes front coilovers
Old Dec 29, 2010 | 01:25 PM
kammi10's Avatar
Car: 1989 camaro
looking at putting a set of coilovers on the front of my car so i can get the stance i want and not have to deal with pulling the springs in and out to get it right. plus if i want to adjust them up or down it would be much easier..
so who all makes a coil over set up that is strickly bolt in and doesnt take an fabrication..
Old Dec 29, 2010 | 01:53 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
Re: who makes front coilovers
spohn
Old Dec 29, 2010 | 03:40 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
The Kit Spohn offers is probably the best on the market if going coilover. I know what you mean about dealing with coil springs they can be a pain! Most people will recomend picking up a strut tower brace as well which probably isnt a bad idea.
Old Dec 31, 2010 | 09:29 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I just installed the Spohn coil over kit on my car this winter. Its a nice bolt in piece. Sure beats dealing with the stock springs. There are a couple of other kits out there but none of them are as beefy as the Spohn ones which to me is important if you drive your car on the street. The spohn kit has plates that re-enforce the strut mount area while the others don't.
Old Dec 31, 2010 | 10:25 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Not 100% bolt in, you still have to modify your struts slightly to fit any coil-over kit
Old Dec 31, 2010 | 11:06 AM
Car: 1990 Camaro RS
Are you talking about the flat cover peoce on the top of the strut? I thought it was only certian struts that had to be modified?
Old Dec 31, 2010 | 12:21 PM
That's what I'm refering to. Maybe not all struts need to be modified, but I know for sure that at least Lakewoods & stock/Monroe struts do
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Fronzizzle
Aug 17, 2015 02:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
