Rear Lower Shock Bushing Part#
Old Dec 31, 2010 | 04:46 AM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Anyone happen to know of a direct replacement lower shock bushing for a Third Gen? Preferable something I can get at Auto Zone or pep boys? I know they stock Energy Suspension products. I wouldnt mind ordering it online if I had to. I was trying to find a part number online and I came up with nothing. I was hoping someone here had went through this already and can point me in the right direction. Thanks!
Old Dec 31, 2010 | 08:29 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Rear Lower Shock Bushing Part#
Are you talking about the bushing that sits under and over the shock tower? If so I used Energy suspension. Autozone usually stocks a box of the endlink size bushings and washers,they work great.
Old Dec 31, 2010 | 02:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i think he means the bushing on the axle side of the shock. I dont believe there is a part number for it, since its part of the shock. If its failed, the shock is probably shot as well. new shocks are pretty cheap really.
Old Dec 31, 2010 | 03:31 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
I dont have a bushing failure. I have a 84 Supra with a Independent Rear. And a common mod people do with these Supras and Cressidas is run third gen rear shocks when they run a shorter spring to avoid excessive bouncing.
Since they dont make KYB AGX for my car, I had to order some for another car. And the lower bushing is different. A vendor in the Supra community is currently out of stock on these bushings and Im a little impatient at the moment.
Old Jan 1, 2011 | 01:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
is it just a smaller/larger bore in the bushing? you can use it but just using a different bolt for the mount and some washers if that helps, maybe even just for tempory purposes. just make sure its a grade 8 bolt (10.9 is metric)
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
Nov 16, 2015 01:13 PM
