Bleeder Vlave Stuck
Old Dec 10, 2001 | 10:03 AM
SgtSkip's Avatar
Bleeder Vlave Stuck
Before I break this thing, how do you loosen a stuck caliper bleeder valve. I really need to flush my fluid!
85T/A 305/QJ work in progress.
Old Dec 10, 2001 | 01:22 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Try heat. Propane torch kinda heat, not acetylene/oxygen. And not RED hot heat
Old Dec 11, 2001 | 04:52 AM
Eightyninef's Avatar
more than likely you'll be replacing the caliper after it breaks off....
Old Dec 11, 2001 | 08:37 PM
SgtSkip's Avatar
Tought so. I was hoping there was a trick I haven't heard but oh well. I should probably be replacing it anyway since they're original...
Old Dec 12, 2001 | 08:16 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Autozone has rebuilt calipers for $10. Not worth the effort on working on the old one just replace it. The rotors are also $10 if you want to do them at the same time. Helped my braking situation out a lot. I went ahead and replaced the rubber dry rotted brake lines and wheel bearings all at the same time and finished the job for under $100 and felt that it was well spent bringing the car back into spec.
[This message has been edited by brharris27370 (edited December 12, 2001).]
Old Dec 12, 2001 | 07:18 PM
SgtSkip's Avatar
$10 for rotors? I might be ordering them from AZ back east! They're $35 here. Calipers run about $20 or so.
Old Dec 12, 2001 | 09:59 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you do break a bleed valve you can easily remove it with an "easy out" type screw extractor.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
84redta
Sep 19, 2015 09:58 AM
ctoledo0834
Sep 18, 2015 04:16 PM
