Any tricks for removing A-arm bolts?
Old Dec 13, 2001 | 10:52 PM
gravitar's Avatar
I pulled a complete engine cradle/front suspension assembly from a car at the junkyard. I intend on modifying the spindles, replacing the bushings, etc. off-car and then bolting the whole thing up when its done.
I have it stripped down to the point where the only things still attached to the cradle are the A-arms. I removed the nuts easily, and the bolts turn but will not come out. Gentle tapping with a hammer didn't do any better. I'd like not to destroy the bolts, which is what I fear will happen if I hammer on them any harder.
Is there a way of doing this w/o ruining the threads on the bolts, or should I just pound the hell out of them and just accept the fact that they're gonna have to be replaced?
Old Dec 13, 2001 | 11:26 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're trying to get the A-arm bolt out while the spring has tension... good luck "tapping" them out. You'll need to compress the spring to relieve the pressure b 4 those bolts will even think about wanting to come out.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"I don't know the key to success, but the key to failure is to try to please everyone."
Old Dec 14, 2001 | 12:34 AM
iroc5speed's Avatar
been there, tried pounding many hours. had to get bolts burned off, end of story. I hated those things, but it's best to get new bolts anyways, just make sure they're high grade.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Dec 14, 2001 | 07:02 AM
gravitar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by iroc5speed:
</font>
That's what I was afraid of No big deal though.. I had to cut the head and threaded end off the panhard rod to remove it, I guess I'll do the same on the A-arms.
Luckily though, I don't have to worry about springs or any of that.. The cradle/A-arms is sitting in the bed of my truck right now!
Old Dec 14, 2001 | 09:32 AM
gravitar's Avatar
Hey, I think I came up with a solution to the frozen-but-spinning bolts. Remove the nut (those seem to come off fairly easily) and put a piece of scrap steel over the end of the bolt to pretect it. Hammer on the scrap steel with an air chisel for a while, and the bolt should come free! I did two of them that way, the other two gave up with some whacks from a hammer.
Old Dec 14, 2001 | 12:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can put a nut or 2 on the end of the bolt and beat on that with a hammer to break it loose.... just make sure they catch enough threads that you don't damage them.
ICON Motorsports
Eric-86sc
Apr 3, 2016 03:52 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
