cutting springs other questions.
Old Dec 13, 2001 | 06:43 PM
Matt's Avatar
I have eibach springs and they have been on the car for two years. they were sapossed to settle after a while but cant tell any difference. Can I safetly cut a quarter or half a spiral off to drop the car. Also what is the largest tire that can fit on the stock 15inch TA wheels.
Matt
Old Dec 14, 2001 | 08:50 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I cut the Eibach springs in my 92 to get the ride height where I wanted it.Just take a little off at first,once it's cut off you can't put it back.I ended up cutting about 3/4 of a coil off the fronts.(1/4 at a time)
Use a die grinder and 3" cutoff wheel.grind the sharp edge down, so it doesn't try to chew through the A-Arm.Shoot some spray paint on the cut to keep it from rusting.
Not sure about how big of a 15" Tire you can fit. I have the 16"x8" Wheels with 245-45ZR16's.
-Rich-
Old Dec 14, 2001 | 05:44 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Richs instructions for spring cutting sound good.
a stock 15" wheel is 7 inches wide.
The widest tire you can put on a 7 inch wheel and still have an oval, instead of a wedge shaped sidewall is a 235 or at the most 245 series tire. You can go wider but the side wall will take on a wedge shape and the tread will curve out in the center.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
crzycamaro86
Sep 12, 2015 05:51 PM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZ1989
Sep 4, 2015 11:54 AM
tonys91rs
Sep 2, 2015 07:07 PM
