I have had my camaro for a while now, but i dont know if it was ever lowered or not... is there any way i can tell?? My z28 is about 2 inches lower then my friends RS (same year, 1992).
1992 z28 25th Anniversary
All black w/ z28 wing
Flowmaster Exhaust
350 TPI
Check out my car!
Flowmaster Exhaust
350 TPI
Check out my car!
Measure from the ground to the bottom of the wheel opening on the fender. Then post it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
My car is at home right now, i am at college in VA... I guess i am going to have to wait till i get back home next week.
Flowmaster Exhaust
350 TPI
Check out my car!
Flowmaster Exhaust
350 TPI
Check out my car!
