Leveling out the rear
Old Jan 24, 2011 | 12:45 AM
EvilCamaro1992's Avatar
Car: 1992 Camaro RS 25th Anniversary
Ok, so I need to make sure my rear springs are level after cutting. Since it is a solid axle and level ground is rare, should I put a floor jack under the rear axle housing and jack the car up a little bit and then measure. I just want some others input on it, thanks.
Old Jan 24, 2011 | 04:17 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Leveling out the rear
If you want to lower the car, then buy powering springs rather than cutting the stock ones.
Do not jack the rear up.
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
Thornburg
Aug 25, 2015 01:46 AM
mizz0313
Aug 12, 2015 06:45 AM
