IROC Springs
Old Jan 27, 2011 | 01:29 PM
vette_1989's Avatar
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
IROC Springs
I have a 1987 Z-28 that I am cloning into a IROC. Are the Z-28 front and rear spring different from the IROC. If so, if I install new IROC springs will this change my suspension more than just a new front end alignment?
Thanks,
Joe
Old Jan 27, 2011 | 01:37 PM
bad_to_the_bone's Avatar
Car: 89 iroc-z
Engine: 427 bbc
Transmission: borg warner t-5
Axle/Gears: 3:23 posi
Re: IROC Springs
i beleave the iroc springs are a little stiffer but not sure and if you had changed the springs it would be recomended to do an alingment if the ride height changed to be sure on the springs you could call a local parts store and find out if they have the same part number or could call the dealer they might know
Old Jan 27, 2011 | 03:52 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: IROC Springs
IROC springs are stiffer than regular springs. IROC springs can be found on the Spohn website.
Not sure about the alignment but getting one if the car never had one is probably a good idea.
Old Jan 27, 2011 | 04:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: IROC Springs
Unless you turn a tie rod or change the strut tower mount to a different position, no need for an alignment (unless your car already has an alignment issue).
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
