anybody used this spohn setup?
Old Feb 7, 2011 | 11:36 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
thinking on using most of this setup for my daily/ autoX camaro, tell me your opinions.
http://www.dragzine.com/project-cars...is-renovation/
Old Feb 8, 2011 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: anybody used this spohn setup?
skip the coilovers, drag bar and the manual rack if its for AX, other than that, they are good parts, but maybe excessive. Shocks tires steering parts and brakes should be replaced/upgraded first IMO, before all the shiney stuff is needed
Old Feb 9, 2011 | 10:52 AM
Car: 1990 camaro rs
Engine: 305 tbi
why would I skip the coilovers and manual rack? I understand the drag bar but the manual rack should be better thar the original setup, if I'm not mistaken?
Old Feb 9, 2011 | 11:39 AM
87350IROC's Avatar
Car: 87' IROC
Have you ever driven a car with manual steering? Not something I would want on a race car, let alone a daily driver. Whats the motivation?
Old Feb 9, 2011 | 06:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
a manual rack would require many more turns lock to lock than your stock steering, it would be a disaster for a autox or road race car.
the front coilovers limit you in tire size and and generally not used for a roundy round car for that reason. I had them on my 86 for a while and they are not the best thing going, unless possibly on a drag car, along with other parts, to loose some front end weight, and to be able to use a really long, light spring to help weight transfer.
Old Feb 13, 2011 | 10:24 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Deffinately dont want manual steering for a road racing car....
Old Feb 14, 2011 | 11:36 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
STRANGE THEY WENT THRU ALL THAT TROUBLE UNDER THE CAR AND LEFT THE 15" RIMS WITH SQUISHY TIRES. WTF?
Old Feb 18, 2011 | 09:16 PM
Car: 1990 camaro rs
Engine: 305 tbi
ok so should i just skip the setup then? I'd need to at least upgrade steering parts and suspension parts, steering is gettin a little laggy
Old Feb 19, 2011 | 07:38 AM
88WS-6's Avatar
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
Try getting your steering box rebuilt and getting a front end rebuild kit. I have a low mileage 88 GTA and all of that still needs to be done. Squishy steering is something all of our f-bodys have now with their age.
There are tons of posts on here for steering and front end tips to get it more firm.
~Matt
Old Feb 19, 2011 | 11:12 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
NAPA should have all the parts you need to rebuild the front steering components.
You could also order a complete kit from Spohn.
Old Feb 20, 2011 | 01:44 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
go to rock auto to get your front end parts cost less then $100. for all the parts (movtech) made in canada stronger then GM.thicker also. then have them zink plated. less then $30. i like the gold zink my self and had all bolts and other parts finished in that. it cost $60 now rust free for ever. spindles and backing plates done in that price also.
this is with the sphon A arms K Member and Coil overs (drag set up)
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
