Braking front end clunk
Old Mar 18, 2011 | 01:52 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
So my car has a front end clunk noise that it does no other time but when Im braking. Not going over bumps or turning, just when I brake softly as I am about to come to a stop. If I hard brake It will not make any noise. I got a suggestion that It may be the K member bolts loose, could that be what it is? I am stumped because I would think that if anything was loose it would make noises going over bumps and stuff. The person that told me this knows his stuff, he is like a F body guru. I would just like other suggestions to try too. Thanks!
Old Mar 20, 2011 | 11:11 AM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Braking front end clunk
No body has any ideas? The clunk and squeak is only when I brake. When I go over bumps and stuff its fine. Thanks!
Old Mar 20, 2011 | 11:50 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if its only when you brake, something with the brakes is making the noise, possibly a loose or worn caliper pin, or pad. You can check the k-member bolts easy enough, but i doubt thats it.
Old Mar 20, 2011 | 06:15 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Ok, so I just bought new pads for the front brakes and will be changing them next weekend. I will let you guys know what happens!
Old Mar 20, 2011 | 09:53 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Hey man I would look at the strut mounts and make sure the rubber looks good. The same thing was happening to mine and that was my fix but mine looked really bad. Just an idea. Or check yoir ball joints too
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
novaderrik
Aug 10, 2015 12:44 PM
