Front Strut replacement question
Old Mar 28, 2011 | 04:25 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Do you need a sping compression machine? and can in be done without a lift?
Old Mar 28, 2011 | 06:36 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Front Strut replacement question
No compressor or lift required. Modified Macpherson strut can easily be changed without special tools.
Jack up car and support by lower control arm and remove wheel.
Unbolt brake flex line. Unbolt 2 large lower mounting bolts (I think they are 15/16").
Unbolt upper strut rod nut, and the strut will fall out.
Old Mar 28, 2011 | 08:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
^what he said
just jack up the car, put it on jackstands, and support the a-arm you are working on with the floor jack. dont forget this part, the spring and everything will blow out once you remove the strut bolts if you dont support the arm. I actually had a brain fart and did just that a couple weeks ago when tearing apart the front of my 92. It was interesting to say the least.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 11, 2015 02:59 PM
